VAT disallowed on liquidated debtor
  • Madgek
    • Sep 2016
    • 3
    I am new to this forum and wonder whether any of the members can possibly assist?
    SARS has disallowed vat claimed on a liquidated debtor in terms of Section 21 of the Vat act and listing as its objection that credit notes issued effectively cancel the supply. This despite the credit note clearly indicating that it is a bad debt, and providing SARS with the provisional liquidation order.
    I've moved this to the tax forum where it's more likely to be seen by the right folk to advise.
    • bammer
      • 20
      Originally posted by Madgek
      Irrecoverable debts are not credit note events as envisaged in terms of section 21 of the VAT Act (i.e. you cannot issue a credit note in terms of the VAT Act in respect of bad debts that have been written off).
      Nonetheless, you are permitted to claim an input tax deduction in terms of section 16(3)(a)(v), read with section 22(1) of the VAT Act by applying the tax fraction (14/114) to the amount actually written off. The deduction may only be claimed if you have made a taxable supply of goods or services and accounted for the VAT in a previous VAT return.
        Hmm had forgotten this, simply because I no longer do the actual VAT form any more, and my auditor does it. If I am not mistaken, there is an entry on the form for Bad Debts, and also for Bad Debts recovered.
        • Madgek
          • Sep 2016
          • 3
          Vat Disallowed on Bad debt
          The credit notes were issued against a "bad debt" debtor, did not reduce vat on the supply of goods, and was claimed for under "Adjustments - Bad debts".
          If I understand your comment correctly, credit notes should not have been issued at all, but adjustments made via journal entry?
          • bammer
            • 20
            That is correct.
            Note the following extracts from the attached VAT 404 - Guide for Vendors, which provides more detail in this regard (footnotes omitted):
            CHAPTER 14
            DEBIT & CREDIT NOTES
            14.1 INTRODUCTION
            A debit note will normally be issued by the supplier when the tax invoice for the supply has already been issued and the previously agreed consideration is subsequently increased. Conversely, a credit note will normally be issued by the supplier when the tax invoice for the supply has already been issued and the previously agreed consideration is subsequently reduced. A credit note is also issued by the original supplier when faulty goods are returned by the customer. Debit and credit notes therefore provide a mechanism to support the necessary VAT adjustments required or allowed where an event has the effect of altering the original consideration agreed upon for a past taxable supply, after the tax invoice has already been issued, or the vendor has accounted for the supply on a VAT return.
            14.2 WHEN MUST DEBIT AND CREDIT NOTES BE ISSUED?
            The following are the circumstances under which it will be necessary to issue a debit note or credit note:
            • A supply of goods or services is cancelled.
            • The nature of the supply of goods or services has been fundamentally varied or altered.
            • The previously agreed consideration for the supply of the goods or services is being altered by agreement with the recipient (including a discount).
            • Part of, or all the goods or services supplied are returned to the supplier (including any returnable container returned to the supplier).
            • The price on the tax invoice was either overstated or understated.
            This will, however, only be necessary if in respect of any of the above circumstances the supplier has either –
            • issued a tax invoice and the tax charged is incorrect; or
            • furnished a VAT return in which the incorrect amount of output tax was accounted for.
            The debit or credit note must be issued, whether or not the supplier accounts for tax on an invoice or payments basis. The issue of a credit note is not required when a prompt payment (settlement) discount is the reason for the reduction in the consideration, provided the terms of that discount are clearly shown on the tax invoice.
            CHAPTER 15
            ADJUSTMENTS
            15.1 INTRODUCTION
            This chapter identifies those situations in which a vendor will be required to make adjustments to input tax or output tax. It explains when the adjustments should be made by the vendor and what the amounts of the adjustments should be.
            Adjustments to input tax or output tax will arise in respect of taxable supplies, for example, where –
            • an irrecoverable debt is written off by a vendor;
            • a debit or credit note is issued or received by a vendor;
            • early payment of an account gives rise to a prompt settlement discount;
            • faulty goods received by the customer are returned to the supplier; and
            • a change in the extent of taxable use or application of goods or services occurs.
            15.2 IRRECOVERABLE DEBTS
            A vendor who accounts for VAT on the invoice basis may deduct input tax in respect of debts which have become irrecoverable. In the exceptional case of a vendor who is registered on the payments basis and who has already accounted for a taxable supply which was paid with a cheque and the cheque is dishonoured, that vendor may also deduct input tax. The circumstances under which such a deduction may be claimed, requires firstly that there must have been a taxable supply for a consideration in money. Secondly, the vendor must already have accounted for the supply in a VAT return. Only then is that vendor entitled to make an input tax adjustment. The adjustment is calculated by applying the tax fraction (14/114) to the amount actually written off as input tax.
            A debt will be considered as irrecoverable if both the following requirements have been complied with, namely:
            • The vendor must have done all the necessary entries in the accounting system to record that the amount has been written off.
            • The vendor must have ceased active recovery action on the debt or handed the debt over to an attorney or debt collector.
            The vendor may then make an input tax deduction in the tax period in which both of the abovementioned requirements have been met. In the case where the vendor subsequently receives payment in respect of a debt written off as irrecoverable, the vendor must account for output tax on the payment in the tax period in which the payment is received.
            • BusFact
              • Jun 2010
              • 843
              I'm not getting this? Why on earth can't you do either a credit note or a credit journal for a bad debt scenario?
              Sometimes a credit note makes more practical sense, for instance, if it is used in your commission calculations in your accounting package and you don't want to pay commissions on bad debt sales.
              • Madgek
                • Sep 2016
                • 3
                My view exactly!
                • bammer
                  • 20
                  My understanding is that the VAT treatment of a supply is generally determined by what happened in law. Subsequently, this event is captured in the accounting records. It follows that there are many entries in accounting that have no VAT effect (e.g. depreciation, bad debts provisions, etc.).
                  If a sale was made and the recipient refuses to pay, the supplier may take legal action against the recipient. However, if a credit note is issued, the supplier is effectively notifying the recipient that it no longer owes the debt.
                  With regards to commission, this usually involves an agent, making a separate supply of services to the principal for a fee (usually called 'commission') and the agent is required to issue a tax invoice to the principal in this regard. I need to consider the agency agreement to determine the VAT consequences - in the unlikely event that the agent's supply is deemed to be cancelled if it made a supply of goods or services on behalf of the principal to a recipient that is not settling its debt, the agent will issue a credit note to the principal.
                  • BusFact
                    • Jun 2010
                    • 843
                    Fair point, although I suspect that with most small businesses, the debt is being written off because it is not recoverable, so whether the debtor owes it any more or not is a little irrelevant. I do however accept that there are situations where one might claim a bad debt VAT refund when its really a doubtful debt with a lengthy legal battle ahead - mainly a cash flow consideration I suspect.
                    I also struggle to see how the law would interpret a credit note which explicitly states that the debt is bad or irrecoverable, as being a release of debt. But that is a lay view, not a legal opinion, and the law has done stranger things.
                    In any event I still don't see what it has to do with SARS. The VAT effect is the same.
                    My situation is much simpler. Its my staff. The accounting package calculates their commission based on gross profit from invoices and credit notes. It cannot do so with journals. They are not entitled to comm on bad debts. Forcing me not to process credit notes, just creates extra manual work and increases chances of comm errors. Its quite nonsensical in my opinion.
                    Keep in mind, this is all that this is, just an opinion. Your posts may be more factually correct.
                    • bammer
                      • 20
                      As mentioned above "Debit and credit notes therefore provide a mechanism to support the necessary VAT adjustments required or allowed where an event has the effect of altering the original consideration agreed upon for a past taxable supply, after the tax invoice has already been issued, or the vendor has accounted for the supply on a VAT return." (my emphasis)
                      Since the amount of consideration agreed upon between the supplier and the recipient did not change (i.e. the recipient is still liable to settle the debt whether written-off or provided for), a credit note cannot be issued in terms of section 21 of the VAT Act, whether or not it explicitly states that the debt is bad or irrecoverable. It follows that where a vendor issues a credit note (for VAT purposes) for this reason, it will be invalid and SARS will likely assess the vendor, to the extent that it claimed input tax deductions which cannot be supported by valid credit notes as is required in terms of sections 16(3), read with 16(2) and 21 of the VAT Act (amongst others).
                      SARS may also argue (in terms of section 234 of the Tax Administration Act) that an erroneous, incomplete or false document has been issued by the vendor and if so issued willfully and without just cause, the vendor is guilty of an offence and upon conviction, is liable to pay a fine or be imprisoned for a period not exceeding two years.
                      It may seem like the VAT effects are similar but the essential difference for the purposes of this discussion, is that when a supplying vendor issues a valid credit note in terms of section 21, to a recipient, the recipient is required to adjust the amount of input tax it previously claimed (or was entitled to claim) by increasing its output tax for the period in which the credit note was received. In other words, the supplying vendor has to generate and deliver (whether electronic or otherwise) the credit note (i.e. document containing the particulars mentioned in section 21(3) of the VAT Act), to the recipient - which will likely not be the case in respect of a debt that has gone bad.
                      However, where a recipient incurred VAT on a supply of goods or services and claimed same as input tax and subsequently, the recipient does not settle the full amount that is due to the supplier within a period of 12 months (e.g. a typical bad debt scenario), the recipient is required (in terms of section 22(3) of the VAT Act) to make an adjustment (usually by passing a journal) which has the effect of reducing the amount of input tax previously claimed to the extent that it made payment in respect of the said goods or services.
                      It may be worthwhile to also consider the impact from an income tax and accounting point of view, i.e. what is difference for income tax and accounting purposes between a debt that is written-off (and/or provided for) as opposed to crediting the debtor (to effectively reduce sales/increase cost of sales).
                      It is hard to imagine that generating and delivering/posting/emailing credit notes to recipients (albeit incorrectly) takes less effort than passing a journal. Perhaps you should contact your accounting service provider; who knows, it may have an easy solution.
                      • BusFact
                        • Jun 2010
                        • 843
                        Thanks bammer. I'm now starting to see the reasoning behind it. As a lay person I still find it pedantic and unnecessary, but that is merely an opinion. For all those readers following this post, listen to bammer, I'm merely venting frustration.
                        The processing effort is the same, but processing a journal has no affect on the commission report generated by pastel in my case. Therefore once I have done the journal I then need to additionally:
                        1. Remember to follow this extra process.
                        2. Find the costings for each item originally invoiced.
                        3. Manually calculate the gross profit or rather loss for the journal. (would not be fair to reduce comm for the whole invoice amount).
                        4. Verify the rep's sales comm % level for the month and check if the adjustment is not going to drop him into a lower % rate.
                        5. Calculate the comm that needs to be credited, after searching for the dusty old calculator.
                        6. Print out the comm report and scratch out the total and then write in my adjustments calculated above so that it can be explained to the rep.
                        The credit note alternative is far less a PITA. All this because some SARS suit decided one day that he had a specific definition in mind.
                        Sorry bammer this is not directed at you, but at bureaucracy. Thanks for taking the time to clarify the matter.
