E@syfile opening issues
  • Heidivf
    • Jul 2014
    • 48
    [Question] E@syfile opening issues
    Hello
    It is that time again when some of us struggle with e@syfile and this year it is my turn
    I updated E@syfile from within the program and gave error message - can't remember the exact wording. I then proceeded to uninstall E@syfile and download the new version from SARS. When I try to open E@syfile, the little clock goes round and round and does not open the program. A few years back, when this happened, it had to do something with Adobe Air and the version you were running - at that time you couldn't be on the latest version of Adobe.
    For those who have the latest E@syfile running, what version of Adobe Reader and Adobe Air are you running and what other tricks can I try to get this program to open?
    I am running Windows 10 64-bit
    TIA
  • Mike C
    • 2894
    Hi Heidivf - I have Java 7 update 64 in both 32 and 64 bit installed. Flash Player 25.
    • Heidivf
      • Jul 2014
      • 48
      Hi Mike
      Thanks - I think my java is the culprit. Fixing it now and holding thumbs
      • Heidivf
        • Jul 2014
        • 48
        It opened and restored my backup
        • Mike C
          • 2894
          • JaredAdd
            • Apr 2017
            Greetings,
            Where did you get Java 7 update 64 in both 32 and 64.
            My e@syfile has greyed out areas and doesn't allow me to restore or synchronize. I have java 6 update in both 32 and 64bit as they suggested and also the java 7 update 80 in both 32 and 64bit.
            Please if anyone could helped I would appreciated it. It been over 9 days with different combinations and nothing works. I'm on windows 10 v1607.
            • Mike C
              • 2894
              Hi JaredAdd - I see on the Easyfile info it says:
              Java 6 is required (both JAVA and AIR included in e@syFile Employer setup file). Later versions of Java may be used, but version 6 must be installed as well . Should you experience any problems or need more information click the button below.
              And there is more info if you click this link:
              SARS collects taxes & customs. File returns, check balances & find branches. We build a compliant & prosperous South Africa.
              • JaredAdd
                • Apr 2017
                HI Mike C,
                I did all of that and still nothing. If anyone has any other solutions, I would be grateful.
                Thanks anyway Mike.
                • Mike C
                  • 2894
                  Hi JaredAdd - You didn't comment on your Adobe Flash player. Is that up to date?
                  It also appears to be important with this update that any previous version of Easyfile gets uninstalled before the latest is installed. I assume that you have done that?
