Easyfile Declaration Greyed out
  • TanyaOel
    • May 2018
    [Question] Easyfile Declaration Greyed out
    Good day all,
    I have tried phoning SARS regarding the below matter since 09/05/18 and they are still busy investigating with their technical department.
    On easyfile I have the latest version of easyfile, adobe air & java. I have deleted them all and re-installed everything but I still get the same problem.
    The problem I have is when I go to the declaration and open it, it's greyed out. The declaration don't open for me to complete. I only see the top buttons which is File, Save, Print and close. I can click on close but the rest don't do anything.
    Please can someone advice if they had the same problem and how they fixed it as I am stressing cause the deadline is 31/05/18.
    Thanks in advance.
  • Mike C
    • 2894
    In years past Easyfile used an older version of Java and some users had to reinstall that version. I think it was Java 7 update 67. Don't know if that could be the issue?
    • andrewwhitaker
      • May 2018
      Fix the emp501 problem
      I battled with the same problem and eventually came right yesterday. You have to delete the file emp501.swf and it will then automatically update with a new one. The file is located in Users/username/appdata/roaming/easyfileemployer/localstore/flexiforms
      Originally posted by TanyaOel
      Good day all,
      Thanks in advance.
      • TanyaOel
        • May 2018
        Thank you very, very much Andrew it worked.
