E@syfile employer V6.0.0 login failure
  • Laurence Lombard
    • 20
    I was required to update to V6.0.0 two days ago and now I get a "login failure" message. I phoned the helpline and apparently there is a problem on their side. Anyone else encountered this problem? Let me know when it is fixed please.
    • 22810
    When it comes to software development, version numbers x.0.0 normally comes with some degree of pain
    When you say "log in failure" is this logging into E@syfile itself or synchronising with the SARS server?
    • geraldenek
      • Jul 2008
      • 229
      I have the same problem on my computer that you can't even log in - Laurence just check that you have the latest version of Java and Adobe according to SARS requirements apparantely this should solve the problem
      Geraldene Kapp
      Professional Tax Help
      www.mytaxhelp.co.za
      • Christel
        • Feb 2012
        • 361
        Hi there, I also experienced the "login failure" when I tried to login with the ADMIN code. You have to login with one of the other User login's.. remember when you first downlaoded the software, way back in 2009, it made you create 3 logins, one was the ADMIN, then 2 others. I used to always just login as ADMIN, but now it does not allow you to... at all... I have already submitted 5 recons so far for 201202 .... 78 more to go!
        • Laurence Lombard
          • 20
          Ha - got it sorted. Thanks everyone for your input. I uninstalled V6.0.0 (In Windows 7 via Start>Control Panel>Programs and Features) and installed V4.3.3 (which I had downloaded just a week or two ago). And this time it thought I was a first timer, so it asked for ADMIN password and two usernames, so I could enter all that from scratch(1). Then I restored a backup and everything was hunky-dory. Then I uninstalled V4.3.3. and installed V6.0.0. The ADMIN and 2 username bit did not come up but it accepted the username/password that I had just re-created under (1) above. Restored the backup and everything seems to work. It could well be that with all the fiddling I had used the wrong username. I have 8 pages of usernames and passwords collected over the years - only 3 pages are meant to be current, but I am too afraid to throw the older ones away.
          • gabrielleb
            • 16
            same here!!!!!! how come i am not the least surprised. what a waste of precious holiday time!
            • gabrielleb
              • 16
              hang on <maybe you should check back in a day or two cos i installed from new on another pc and it worked for round 24 hours and ....then didnt!!!!
              • gabrielleb
                • 16
                mmmm mostly i find all their software comes with a huuuuge degree of pain
                • Bertievn
                  • 74
                  Got similar problem , can login and loading data base but then receive message that login information does not match that of your local information and not allowed to access E@syfile.
                  Did uninstall installed older version but no luck.
                  This is a Windows 7 Home Premium
                  • Laurence Lombard
                    • 20
                    I must agree. I thought that I had it sorted (see post #5), but maybe/probably not. After I had uninstalled V6.0.0. and re-installed V4.3.3 things looked promising. It prompted me for two usernames and I selected new usernames. I was the prompted to upgrade or download and install V6.0.0. I tried the upgrade option but then you have to constantly check that the program does not timeout. After an age of downloading I slipped on a timeout and lost the upgrade, so I downloaded V6.0.0, uninstalled V4.3.3 and installed V6.0.0. Then I restored a backup and I think after that it did not accept my new usernames but my original one - maybe that happened during the restore.
                    Anyway now when I select View employees and select the company and a period I get the message "PENDING SUBMISSION There is a pending online submission that has not completed successfully. Please press OK to complete or Cancel to reset the submission. You will not be able to make alterations that could affect this submission until it has completed successfully" Then I press OK and I get taken to the "submit to SARS" page but there is nothing pending.
                    This is indeed a mysterious beast. i will leave it for a while and re-install V4.3.3 but i suspect it will force me to upgrade
                    • Bertievn
                      • 74
                      Yes you wont be able to submit 2012 info on older version as data base work different
                      Did not mention on my first posting that version 6.0.0 works perfect on Windows 7 Ulitimate on Laptop but not on Windows 7 Home Premium on netbook
                      Might be memory problem
                      • gabrielleb
                        • 16
                        please note that i have been in touch with the call centre and they tell me they are aware of the problem we are all experiencing............. they say wait patiently for a new version......that might ..... or might not solve the problem! (or might create a completely different problem!!!!)
                        • nkawit
                          • Dec 2011
                          • 184
                          anyone else getting login failure trying to synchronize?
                          █► AllWorldIT ~ www.allworldit.com ~ International IT Solutions
                          █► Wholesale ADSL & Hosting, VPNs, Firewalls, Online Backups
                          • gabrielleb
                            • 16
                            yes, sars suggest we wait until they can fix the problem that they readily admit is theirs
                            • Mike C
                              • 2893
                              I got this too - was working fine on Sunday, and Monday the problem occurred. What I did eventually (I am still using Windows XP) was to go to C:\Documents and settings\(your user name)\application data (which is a hidden file)\ and found a folder called "easyfileemployer.(many numbers and letters). I deleted the whole folder (hoping that I could restore it from the recycle bin if necessary) and restarted e@syfile. It asked me to enter my password as if for the first time, and then opened up for me. I restored from my backup and was able to work on it again. Hope this helps.
