Playing with Math...
    You are married and you doing it for the health of your wife. The stairs exercise, therefore the 10th floor. You and or your wife deem 5flights of stairs sufficient for now.
    edit "I am no doing it for health"
    Because the writer only seems to be referring to him/her self, I may refer to another person when I say it’s for the wife’s health)
    • vieome
      • 540
      Originally posted by Dave S
      4. Are too short to reach the higher buttons and/or left your high-heels on the bus
      Close enough , I am a migit, or PC(small person)
      • Dave S
        • Jun 2007
        • 733
        YeeeeeeHaaaaa!
        Today Defines Tomorrow
          It is seemingly obvious that Velocity = Displacement/Time and that Speed = Distance/Time yet there is a condition where Velocity = Speed... The exception that proofs the rule? Maybe... [It is easy you don't have to google it ]
          • Dave S
            • Jun 2007
            • 733
            Only if an object is travelling at a constant speed, in a straight line, in a constant direction, without effect of acceleration/deceleration, between points "a" and "b", can it be said that the object velocity = the object speed. In such a case displacement would be equal and we now only require to calculate the distance/time.
            Picture in your minds eye, a bullet fired from a gun, when the bullet leaves the muzzle of the gun, this is the last point where the velocity and speed of the bullet are equal. As the bullet loses momentum so it begins to fall to earth, thereby changing it's direction and its displacement, eventually the bullet will stop at some point. A straight line to that point [where the bullet landed] is the displacement (or the distance the bullet has moved away from the gun), divide this by the time it took for the bullet to get there, equals the VELOCITY of the bullet. Now imagine the full arc that the bullet has travelled, (or the distance the bullet has travelled), divide this by the time it took for the bullet to get there equals the SPEED of the bullet.
            • Dave S
              • Jun 2007
              • 733
              Here's one for the physics folks...
              A ship sails straight from point "a" to point "b" across the ocean, it covers a distance of 3000Kms in 150Hrs, and it's average speed is 20Knt, however the actual distance from "a" to "b" is only 2500Kms and the ship's velocity is 16.667Knt, explain how this is possible?
              • vieome
                • 540
                The ship moves on a zig zag course from a to b
                • vieome
                  • 540
                  Not so much maths or english the following, but more to make one think, I think!
                  Why doesn't Tarzan have a beard when he lives in the jungle without a razor?
                  Why do we press harder on a remote control when we know the batteries are flat?
                  Why do banks charge a fee on 'insufficient funds' when they know there is not enough?
                  Why do Kamikaze pilots wear helmets?
                  Why does someone believe you when you say there are four billion stars, but check when you say the paint is wet?
                  • Dave S
                    • Jun 2007
                    • 733
                    Yes, but not in the way we imagine a zig-zag motion. The ship sails STRAIGHT from "a" to "b" means it did not zig-zag (left to right), but rather followed the motion of the waves, zig-zag up and down, therefore accounting for it's extra travel distance.
                    • Dave S
                      • Jun 2007
                      • 733
                      Funny old world we're in...
                        As much fun as Dave S's answer was, the simple answer is when the object is stationary - i.e. both distance and displacement = 0
                        QED
                        p.s. - on the North Pole one, you have to go due South, then Due East (or West), then due North to end up at your original point. Take a 90% angled turn at each point and you'll end up (approximately - curve of earth hurts a little bit here) 5km due South of the North Pole.
                        Essentially the difference between an equilateral triangle and a square, the angles matter - even at the North Pole.
                        • Dave S
                          • Jun 2007
                          • 733
                          #27
                          QED
                          On the first question, you are right, this is the second case where velocity=speed.
                          On the north pole one, I will concede that the instruction to turn left (right) by 90 deg. is misleading, and should have been "turns 90Deg. and walks Due East (West)" would have been better.
                          However, when one does turn through a given angle on the earth's surface and then walks a straight line, that straight line is actually going to follow the curvature of the earth, to demonstrate this. If you were to walk "in a straight line" toward the East, from the point you are now (Durban assumed?), logically you would (at some great future date) arrive back at the point where you started? Physically, however, this is not the case and you would carry on walking, until (eventually) you would arrive at the South Pole. The same would be true if you were using a compass. But if you used GPS co-ords, you would make it back to where you started (your walk line may not be straight). This is simply the effect of the magnetic attraction (or lack thereof?) of the poles. There is one place on earth where one can walk in a straight line, East or West, and arrive at their exact starting point without GPS Co-ords, and without a compass (provided you can maintain a straight line?). Does anyone know where this is?
                          PS. Hint, It does depend on the time of year, and the continent you start from. Don't forget the 23Deg. axis inclination (centreline of orbit in relation to the sun).
                            Sounds about right... Funny thing is I knew you where going to use the bullet example... Now if only I can figure out the lotto numbers
                            • vieome
                              • 540
                              #29
                              3 15 17 19 21 47
                              • Dave S
                                • Jun 2007
                                • 733
                                #30
                                Strange you should mention the lotto numbers, I've always had the correct numbers in every draw since 2001, problem is they keep drawing the wrong numbers...
