They are not that expensive!!!
    I am writing to you today in hope to that you can take this post to heart. We all have friends that consume alcohol it is nothing new and for the most part harmless. Unless the person gets violent then I would recommend handing them over to the police.
    Other than that I want to tell you how you can save your friends job or even your own job. Also to save lives! Yes it is true zero tolerance policies are enforceable and neither the CCMA nor the Labour Union can save your but if you go to work stone drunk. They can try but it is a long shot at best.
    So I got some of my friends a breathalyzer tester. You can get them at pharmacies or gadget shops. They cot between R100 to R350 and a good one can set you back a bit more but for the most part they are not that expensive. I recommend get one and test it at home make sure it works correctly. Best way to test is I find is “mouth wash” . Also don’t test yourself after using mouth wash. Give it a few moments.
    This little device can tell you that you don’t belong at work or behind a steering wheel. The alternative is a car accident and or losing your job.
    I few good people lost there jobs over bad decisions... So come on do the right thing get one if you need one or give one if your friend needs one.
    Choice is yours.
    Be safe!
    I think you pretty much know, that if you have had more than two or three drinks, you are over the limit ! What you should be carrying with you all the time is the telephone no of Goodfellows or one of the cab companies so that you can call them to pick you up and take you home.
      Agreed. That said you get people that party till they drop and when they wake-up they think they are ok because they cannot remember the amount of alcohol they consumed nor have a good idea on how much time has passed. So there is a true danger that they may drive a car or go to work “still intoxicated” Especially in South Africa we get people that can function normally while they had a few drinks behind them.
      So this is basically just reality check to see that you are ok to drive and go to work. If you are the informed responsible drinker there is always a chance that forgot something so it remains a plus for them to have this device. But it is simply a must have if the person in question is a hardcore drinker.
        I really doubt if a hard-core drinker is to going to blow in the little device and go "Oh my, I'm still p1$$ed, I will just sleep in the bar tonight" or "Oh my, I am still p1$$ed from drinking last night, I will just call in sick today and sleep in"
        The point that I am trying to make is that a hard-core drinker is irresponsible to start with, he won't get a taxi every night and he sure wont call in sick every day.
          I want one just to see how high I can score
            I'm just picturing this:
            When an employee calls in and says "Hi boss, not coming in to work today because I'm still over the limit from drinking last night", what am I supposed to say?
            Or think for that matter?
            • eina26
              • Jul 2013
              • 40
              Hey teco, your signature kinda ruins everything you wrote.
              • Dave S
                • Jun 2007
                • 733
                I'm with Adrian on this one, a hardcore drinker is an irresponsible dragon, or he/she wouldn't be a hardcore drinker in the first place.
                Today Defines Tomorrow
                  Well I know of a few hardcore drinkers that use the device and behold they are still employed. So yes hard core drinkers will use the device because they value there employment otherwise how can they afford their habit?
                  Secondly these hardcore drinkers acts more “responsibly” The truth is alcohol takes the time it takes to go through your system but by consuming a meal that consist of heavy proteins will dampen the body’s ability to absorb the alcohol. Also remember that your body produces alcohol naturally in a small amount by adding more in your blood can result in a “higher positive” reading then the alcohol consumed.
                  Mixing your drink behaviour by switching between alcohol and none alcoholic drinks helps the metabolism deal with the alcohol. But normally it comes down to “how much you drank” and how much time you have between then and the next day. If your body had enough time to deal with the alcohol then the breathalyzer will give you an all clear.
                  If not then “that pesky stomach flu” excuse is always handy and true to a degree as your metabolism will be working overtime to deal with the poison.
                  I can’t tell you how many hours you need between your last drink and time your body needs to get rid of it because it comes down to the abuse your body had to deal with so again it is a good idea to have this device handy. It will give you an indication.
                  But the choice is yours, you can drink responsibly or you don’t. But out of experience I know if drinkers have access to such a device they do start to change their behaviour a bit because in the end of the day they need that pay-check.
                    Just as a side note, some larger corporations started to hand out these devices and really the results were worth it. Less dismissals a notable decline in damage of property are the most prominent factors. The general feedback was also good.
                      It is there for my protection,
                      The benefits of having such a device I believe is obvious however... But you get people that tries to shoot down everything. I don't know why
                      If the post is for you or someone you know than why not take it to heart buy the device “one of your choice” use it or give it to someone that needs it. Really at least you give someone a chance where they normally would have no chance. Also it is a wakeup call from a friend that cares.
                      Also what is stopping you to Google for facts and make your own informed decision. My intention was to spark an interest. If nothing else someone years from now will go “this sounds like plan” than I am happy
                      As for my Disclaimer it does its job
                        I like the idea of having testers connected to company vehicles, along with the usual tracker system. The car will start if you over the limit for safety reasons, but it will report it, at the same time taking a photo/video and over the car speaker he will hear your (boss) pre recorded warning "Craig see you in the office first thing" or "Think about this Craig....do you want your job?".
                        I can also see these devices used on request of patrons at restaurants just before leaving for home, as a special added service.
                        But Tec tell me why this topic, what recent event made you think of this, was there an incident?
                          Given the fact that those cheap ones are for one-time use only the market for social use will be extremely limited.
                          A proper reusable tester will cost RX000, who is going buy that? Testing Freaks?
                          I guess the cheap one will have its place, but will mostly dwell unused in the handbags of control-freak woman modelling around the mall
                          Tec, give me hypothetical examples of how You would use it.
                            You will never get away with putting them in company vehicles. The staff would simply use mouthwash all the time to render them useless.
                              Dam you right, they will do that the bastards. I guess I will have to invent a non-invasive way to get blood, shit then I am screwed again they can get a blood transfusion
