Guess The Tool - The Forum SA
Guess The Tool
    It could also be a tool used to express the dimensions of the Golden Ratio which would mean that she is probably a painter or draws freehand!
      It’s for setting angles (Making patterns) when laying tiles
        She makes miniature things and uses the tool to help make proportions
        Sculpting?
        How Big is it?
        • Marq
          • 1297
          #199
          It is a willy length predictor tool based on the length of the forearm!
          Interesting - I must check this out.
          This is exactly it.
          Golden ratio dividers also known as
          Golden mean Calipers also
          Golden mean Gauge.
          Adrian has the floor again.
          Here are some of Penny's paintings
            Nice paintings Marq, I was expecting one of you as a pirate.
              Wow, that is truly amazing.
                  Castration tool I don't want to ask what you use it for.
                  • Marq
                    • 1297
                    #204
                    I'm guessing its a medical tool. But thats because it says so.
                    Some sort of clamp?
                      I use to work on a farm, it is use to castrate animals with a strong elastic. The 4 points will open up stretching the elastic wide open then the sudden close will cut-off the blood supply and in due time the animal will be castrated. It is inhumane to use it on animals like dogs or cats.
                        IanF is correct - Your turn!
                          Another tool for finishing printing.
                            A round corner paper cutter/notch machine
                              Well done you are it. We don't have the die for a notch/calendar cut.
                              This is for small volumes.
                                A clue - when you push the rectangular knob, a vacuum is produced
