Guess The Tool
    I designed and made this one myself.
    a hint: You don't use it to scratch, measure, play with, or do anything whatsoever with your or anybody else's nuts, bra straps or other kinky bits
      That is a TABLE ........ under that funny looking thing ...............
      Ps...... could it be a tool to match different gear ratios/teeth etc ... ?
        Cable drum for winding up and storing random cables.
          Yes it is a table. The tool is about 130mm in diameter.
          Nothing to do with gears or gear ratios. I would say that the ratio 1:87 is rather significant.
            It’s for scaling models
              No, not for scaling models.
              Cable drum comes close in an abstract sort of way.
                Cable tensioner for steel cables eg brake cables.
                  No, not a tensioner.
                    Does it shine light out of it?
                      No light but I will admit that it does get heated here and there.
                      • league_of_ordinary_men
                        • May 2012
                        • 428
                        #281
                        Does it have something to do with soldering?
                          Very good.
                            • May 2012
                            • 428
                            #283
                            Is it a solder wire dispenser?
                              No, not a dispenser - a reel would suffice
                                • May 2012
                                • 428
                                #285
                                Who's next? Adrian do you have any more good one's?
