load shedding
ID:	264312 (No copyright infringement intended)
        I have one word....ORANIA...need I say more.
          • 22812
          Zapiro nails it again!
            What’s the difference between SA and the Titanic?
            When the Titanic went down it had the lights on!
              Just read this article Jacob Zuma: It’s still apartheid’s fault
              When RSA is burning, bring out the race card, it helps pacify the masses by blaming the whites once again..
                Look at SA what has happened with all the resources, education, skills and wealth then look at what has happened to a place like Orania. Nobody wanted the land and now it is worth 500 mil. Need to prepare my daughter for a regter boer so that I can retire there
                  And so the load shedding buzz has halted for a period of time. It might be a good time to prepare, dont waste money on short term solutions.
                  A simple solution for people who dont have tons of money.
                  A generator ( I use a 2.5 kva for my house) which is stored in the garage, connected via a change over switch at the meter box and a long 2.5 mm extension.
                  Small solar panel with a couple LED lights running off a small battery 7 amp/hr.
                  Small invertor with a deep cycle battery to keep the electronics running, you could also run additional lights off the battery.
                  Gas stove, even an affrox 2 plate will work for power outages.
                  Thats all you need to keep your house going.
                  • Phil Cooper
                    • 645
                    South Africa is officially the most romantic country in the world.
                    We have candle light dinners every night.
                      load shedding
                      And now petrol bombs thrown at our houses, what next. I know we in the dark but no need to light up our houses with fire ��
                      Edit...I have been corrected and told It wasnt a petrol bomb, instead it was a bottle with paraffin and a rag which they lit. Not the same thing.
