Geyser not heating
  • Bonga Mkhize
    • Oct 2017
    Geyser not heating
    Please help, I have 100L Kwikot Geyser its not heating up, I have changed Thermostat, Element and Circuit breaker but water its still cold.
    Welcome to the forum Bonga.
    To be honest, if you've already replaced all those parts there's nothing else I could suggest and in the long run it will be cheaper to get an electrician in. Usually with the correct test equipment it will take less than 15 minutes to to do some quick tests and say for definate where the fault is.
    • rawoke
      • Sep 2017
      • 28
      AndyD is right.. you've basically rebuilt your geyser... :P
      FibreTiger - Compare ALL fibre Internet Providers in your Area
      https://www.fibretiger.co.za
      • Bonga Mkhize
        • Oct 2017
        Thanks for your response, luckily the issue has now been sorted, there was a burst pipe underground it was no visible as it was covered by concrete slab, due to the pipe leak the water was forever flowing out the geyser.
          Glad you found the problem and thanks for letting us know what it was.
