Good day !
I have recently finished rewiring my old house from open wiring to everything now with flat twin + earth .
All the light switches (and plugs) are steel boxes connected to 20mm (or whatever the size was in 1950)steel conduits which protrude into
the roof space . All the conduits have about a 60 degree bend running parallel to the ceiling . They all have a brass bush on the threaded end . All the conduits are bonded together with open earthwire and to the main DB and also to a steel water supply pipe . I will replace this with an earth spike .
For the lighting circuits , I have have fastened plastic Major Tech type junction boxes as close to the protruding pipes as possible . I have fitted a plastic 32mm adaptor to the box with a 32mm flexible plastic conduit from there to fitting over the steel conduit end . 25mm does not fit over the brass bush .
I have taken red 1.5mm panelflex to and from the light switch through the steel and plastic flex conduit into the junction box . The supply to the box and from the box to the light fitting is flat twin + earth. All my connections in the box have been done with Wago connectors - I only discovered them recently and they are a pleasure to work with . I used bootlace ferrules on the flex at the light switch side but not on the Wago side .
My light switches are all Crabtree with steel cover plates . I do not like the plastic stuff . I recently discovered (thanks to the Forum) that I must have an earth wire to the light switch . I am busy pulling in 1.5mm insulated earth wire from each junction box to each switch box
. Should I earth from the terminal on the switch carrier plate to the steel box as well ?
My junction boxes have the rubber type 'gland' and I have slit them and pushed my flat twin through that . The cable is saddled to within about 70mm or so from each box . Is this acceptable ?
I have not done any house wiring since about late 1980s and would appreciate any comment or input as to what I have done.
Thank you
. Should I earth from the terminal on the switch carrier plate to the steel box as well ?My junction boxes have the rubber type 'gland' and I have slit them and pushed my flat twin through that . The cable is saddled to within about 70mm or so from each box . Is this acceptable ?
Thank you
