I recieved this warning today
Mercury poisoning from energy saver bulb!!!
http://www.smashwords.com/books/view/332256Tags: None -
There are more pics, but you may loose two or three suppers as well if I post them!"Nobody who has succeeded has not failed along the way"
http://www.smashwords.com/books/view/332256Comment
Unfortunately that is only one daily risk. We can get infection around any corner. My foot is up on my desk at the moment. I am not sure if it was a spider bite or not that caused the blood poisoning. I believe it may have come from a bit of flux which I ignored that fell onto my foot when welding. I was relaxing at home after work when I was asked to weld something. Without bothering to put on closed shoes I went to the garage wearing open sandals and did the favour. I felt the burn but it was not bad enough to warrant removing the small piece of flux. I am now on a course of 2 antibiotics and was told that had I waited 2 days I would have had to spend 2 weeks in hospital. Fortunately it was caught early so it is responding to the treatment quickly.
OK stop complaining this is worse, much worse
you asked for it
I don't think the inflamation and infection in any open wound is caused by mercury. A lot of the e-mails and reports that have been doing the rounds are just hype.
sourceOne CFL contains a hundred times less mercury than is found in a single dental amalgam filling
5 milligrams of mercury contained in a CFL lamp isn't enough to cause a serious health issue even if the lamp is broken. Also mercury is mainly a neurotoxin and can cause respiratory issues, it doesn't cause skin of flesh damage. The infected cuts are just infections, you can't treat any mercury related symptoms with antibiotics._______________________________________________
