Quickbooks Journey
  • Andromeda
    • Feb 2016
    • 734
    #61
    Even if you process it in a so called closed period, it will add the VAT to the next cycle. If you display the the VAT detail report it will show it in the VAT Exception report. That report lists Previously Claimed, now claimed. In this case previously will be nil.
    • AmithS
      • Oct 2008
      • 1520
      #62
      Thanks Andromeda for the helpful info, is this also how import VAT would be managed in QBs as I believe you can only claim the import VAT once the money has been passed over to customs even though the agent might invoice you earlier...
      • AmithS
        • Oct 2008
        • 1520
        #63
        Hello,
        What is the best way to setup a customer in QBs Desktop Premier 2018 so that you have a unique telephone number per delivery/ship to location?
        I don't see a field for telephone number when clicking on the + icon to add a new location under address details.
        Thanks,
        • AmithS
          • Oct 2008
          • 1520
          #64
          Is there a way to change the default text under the transaction section of statements e.g. change "Balance forward" to "Balance brought forward"?
          Or is "Balance forward" the correct term?
            • 22818
            #65
            There's the note field.
            If it's a regular delivery location, there are a number of advantages to setting it as a Job (essentially a customer sub-account), among which would be to add contacts to the Job.
            • AmithS
              • Oct 2008
              • 1520
              #66
              Thanks Dave, do you know if the credit limit for the customer will work as an overall credit limit for the jobs so they don't cumulatively go over the customer granted credit?
              • AmithS
                • Oct 2008
                • 1520
                #67
                Jobs looks like the way to go... Thanks a mil
                • AmithS
                  • Oct 2008
                  • 1520
                  #68
                  Tested this morning, seems to work.
                  • AmithS
                    • Oct 2008
                    • 1520
                    #69
                    How do I prevent this from happening again!
                    Soooooo my new challenge...
                    I configured QBs to send out emailed invoices and statements today.
                    Sent out 1 test email and 5 invoices to the same client/email address - 6x emails...
                    All emails BCC to gmail address for records...
                    1 of the 5 invoice emails did not go through and was blocked for both the client & gmail address...
                    Mail delivery failed: returning message to sender
                    xxxxx@gmail.com
                    host smtp.ucebox.co.za [xx.xx.xxx.x]
                    SMTP error from remote mail server after end of data:
                    550 High probability of spam
                    • AmithS
                      • Oct 2008
                      • 1520
                      #70
                      xxxxx@gmail.com
                      Also cannot figure out if this means that my server stopped the sending of this emails as it was sent from the QBs software and seen as spam or if the recipient servers blocked the emails...
                        • 22818
                        #71
                        That is the email server which has "blown the whistle" - probably yours given that it's an email to gmail that has not been sent.
                        You probably should talk to your email service provider about the spam detection settings for your account.
                        You can also play with the wording in the covering email, although the issue looks likely to be multiple emails being sent to the same email address in very close succession.
                        • Andromeda
                          • Feb 2016
                          • 734
                          #72
                          In Quickbooks Customer Centre, a record is kept of all emailed Quickbooks documents; the bcc probably is not necessary.
                          The way I read the error message, it is your SMTP server that suspects your own email as being spam, but I may be very wrong.
                          But in any event remove the BCC and try again to a test mail recipient if you can.
                          • AmithS
                            • Oct 2008
                            • 1520
                            #73
                            Thanks guys,
                            So I had a chat with my hosting provider and ISP...
                            1. Blocked email released and trained
                            2. Advised to turn on/activate SMTP authentication. Can this be done in QuickBooks?
                            3. Advised to unblack list IP from Spamhaus PBL. Any experience on this?
                            Thanks,
                              • 22818
                              #74
                              Nothing to do with Quickbooks. It is done on your email server (ucebox.co.za).
                              Are you on shared hosting or do you have a VM with a dedicated IP address or more?
                              Do you manage your hosting with cPanel or some other hosting manager software?
                              • AmithS
                                • Oct 2008
                                • 1520
                                #75
                                Hi Dave,
                                Shared hosting managed via cPanel
                                SMTP authentication I am referring to is e.g. how in outlook you have a toggle for my server requires authentication... Not sure if putting in your email account user name and password is considered as authentication or you have to activate it specifically in the software sending emails (QBs) like how you would toggle it on in outlook... If it makes sense...
