Electrical Installation Guidelines
  • ThabiG
    • Sep 2018
    [Question] Electrical Installation Guidelines
    Good day Guys,
    Would you kindly please advise: What is the BEST Manual/ Guide Book to buy for 'Domestic Electrical Installation Work'?
    • 1495
    The best and only book in my opinion would be SANS 10142-1 Edition 2
    If you don't have it, and understand it, you should not be even thinking about touching electrical
    • SeanM
      • Mar 2018
      • 120
      I would have to agree
      • Lourens.dL
        • Apr 2014
        • 23
        And I concur!
        Sent from my SM-N950F using Tapatalk
        • Darking
          • Sep 2018
          • 16
          I'm coming from the UK where we have different options for domestic electrical installers, installation electricians and maintenance electricians. When I last looked you had SABS 0142 wiring regulations. I have obtained a copy of the SANS 10142 as recommended by you to read. I am very up to date with industrial equipment but I imagine domestic installation will have particularly stringent requirements in the RSA.
            • 1495
            The SABS was replaced with SANS - The wiring regulations whether industrial , commercial , domestic all remain the same.
              • 4927
              There's no 'limited scope' or 'Part-P' shortcut to becoming an electrician in South Africa. There's also no OSG type guide book either, just the regs.
              DEMYSTIFYING THE PROCESS TO OBTAIN WIREMAN'S LICENCES FOR FOREIGN PERSONS By Nick du Plessis Times are tough in the electrical industry in South Africa as well as in the rest of Africa and many f
              • Darking
                • Sep 2018
                • 16
                Thank you for your demystifying link. I have noticed mentioned a Single Phrase Electrical Tester , Installation Electrician and Master Installation Electrician. How do you progress from one to the other?
                  • 1495
                  Registering as a Single , Installation or Master depends on your qualifications and the industry that you have experience in.
                  I have attached the information Brochure on the requirements by Department of Labour
                    Originally posted by ThabiG
                    Good day Guys,
                    who reads books, i use youtube for everything.
                      • 1495
                      "you tube for everything "
                      Maybe that is how you missed the new edition of SANS and the Change in COC documentation
                        • 22812
                        I really hope that's said with tongue firmly in cheek, Ian
                          Actually not Dave. All my wood working skills were learnt from youtube. If i need to find out how to do something i go to youtube.
                          With regards to the COC and new SANS edition, after doing a refresher course at the ECA many years ago i realised how screwed this industry was back then. I am sure nothing has improved in the past 15 years.
                          I still work hands on, just finished 2 factories a 400 amp and an 800 amp supply, cable trays, cabling and connected all the machines. I had to laugh when the property management sent around people to check my work. Every single person who walks into the factory comments about the "attention to detail". Maybe i am 15 years behind with the paper work, watching 2 companies carry out inspection reports in my factory, i am glad i havent wasted my time.
                            It must be friday
