COC CERTIFICATE INSTALLATION CLASSIFICATION- SECTION 2
  • Tshepo Mokoena
    • Apr 2017
    • 16
    I m currently doing a COC for a guesthouse (12 rooms ).Where does the guest house fall under in terms of type of installation .Is it a commercial or domestic type ?
    • 1488
    I would put it as commercial as it will have multiply users vs Domestic
    With that said , are you not using outdated COC's ?
    The new COC's which came into effect 1 August 2021, Old COC's are no longer valid, and only have Permanent installation , Temporary installation , Common area for multiple users according to SANS 10142
    I see ECA coc has left out common areas
    Foreword
    This South African standard was prepared by National Committee
    SABS/TC 067/SC 06, Electricity distribution systems and components –
    Installations, in accordance with procedures of the South African Bureau of
    Standards, in compliance with annex 3 of the WTO/TBT agreement.
    This document was approved for publication in July 2020.
    This document supersedes SANS 10142-1:2017 (edition 2).
    The test report in edition 2 may be used in parallel with the test report in
    edition 3 for a period of 12 months from the date of publication of edition
    3.
      • 22820
      Will you raise that in the Technical Subcommittee?
      • Tshepo Mokoena
        • Apr 2017
        • 16
        Thanks for the response .I think I need to familiarise myself with the new books as I was still using the old one
        sharp, sharp
