Good day all
I was called to a house to COC for a sale, a quick joppie
The incoming 10mm airdeck cable, buried in the ground, split somewhere under the ground to an adjacent plot???
The flat twin and earth wires are build into the walls and some are on the surface and plastered over??
The flat twin and earth wires are in the cavity between the ceiling and corrugated roof. Not sure if there are junctions or not.
I don't see any protection for the twin and earth that runs over the metal strips on which the ceiling is fitted
Three and even 4 flat twin and earth wires are pulled into one 20mm conduit
The DIN rail DB had been enlarged to accomodate a meter or samite breaker or something else
The list goes on and on.... I had not even started testing the wiring in the building
My diagnosis is to rewire everything but how do I do it without chasing the walls and open the roof or ceiling
Will be going back for a few photos a bit later
Stay safe
Stay safe
