Re setting a prepaid meter
    • 1765
    Morning
    During the last spate of load shedding, I was called out on a number of occasions for prepaid meters not switching on again after load shedding.
    When this happens, the display is normal, showing the units available, but the internal contactor has not energised. Don't know why this happens.
    Here is the solution without having to contact the supply authority.
    On Conlog meters, type in the following code: 5649 3153 7254 5031 3471
    For ALL other meter types, type in the following code: 0000 0000 0001 5099 7584
    The above codes trip and reset the meter a couple of seconds later and the contactor will then energize.
    The above scenario seems to occur more with Conlog meters as all these callouts have been to Conlog meters.
    Important:
    Should the meter be of the type with a battery powered remote unit, the meter can still be tripped using the above codes, but it will not
    switch on automatically after a few seconds. The code needs to be punched in a second time to switch the meter on again.
    Make sure the batteries in the remote unit are good otherwise it ain't gonna work.
    Hope this helps.
    A handy bit of info, thanks.
    I see some of the prepaids venders are offering smart meters, have you you installed any of them, if so how smart are they ? Do they offer a daily total like the CBI and sonoff units?
    By the way the crimper has busy with many 35 mm battery cables.
      • 1765
      No. Vodacom apparantly have their own installers for the smart meters. Here they are using Hexing. No meter base. The meter itself is fixed to the wall with hilty's. No anti tamper mode. If the cover is removed, a tamper flag is sent to the service provider.
      • Lesiba325
        • Sep 2022
        Hi there I've been searching for hours for a solution... I tried the above codes and the conlog one seems to reset but the machine as it flashes and starts showing all sorts of numbers but doesn't restore electricity.
        I've got a landis gyr meter
        Please help.🙏
          • 1765
          Is there a smiley face showing on the display ?
          • Lesiba325
            • Sep 2022
            No it still shows sad face and a broken circuit
              • 1765
              That meter has been tampered with. It's in tamper mode. A tamper coupon is required from the administrators of the meter. No other way.
              • Kurt1983
                • Sep 2022
                Hi. My hexing 110 p show a smile face and open circuit we have tried the code and it switch the power on and then after a while it goes of again. There is enough credit loaded.
                Any Ideas?
                • Dylboy
                  • Jun 2020
                  • 777
                  Is their and inverter installed in the house ? It may be backfeedind and then shutting down the meter
                  • acprinsloo
                    • Oct 2022
                    Good evening . I've got a conlog prepaid meter. When I'm cooking on my stove if I switch on the kettle my prepaid meter trips is there anyway I can adjust the load limit on meter so can draw more appliances at once
                      • 1765
                      The administrator of the meter will have the codes to set the tripping current.
                      What size is your main breaker ?
                      If it's a Municipal meter and there are more than one meter on the erf, then the tripping current is reduced by them.
                      • acprinsloo
                        • Oct 2022
                        Thanks will make a turn by municipal regards
                        • Raolane Thabo
                          • Dec 2022
                          Hi. I have a conlog meter, it's on tempering mode since the last loadshedding schedule. I tried resetting but still can't engage. What more can I try.
                          Your help is appreciated
                            • 1765
                            Only the administrator of the meter can assist with resetting a tamper.
                            Municipality, Eskom or private administering company, whichever is relevant.
                            • Linnels29
                              • Apr 2023
                              Morning
                              Important:
                              Hope this helps.
                              Hi there. My prepaid electricity meters keypad is not working. Some keys don't work at all. Others when I press them all that comes up is an 8. I have been trying for a month to get eskom out to see if it can be repaired but I haven't heard back from a single person and I am running out of units and unable to put more in.
                              My box is a Landis+Gr, Sabre type 10-SA012, single phase. It shows a happy face. No error codes. The keypad just won't work. Any ideas on how to maybe fix it? Thanks.
