wood an approved method to blank or support electrical components
    [Question] wood an approved method to blank or support electrical components
    Rules and regs with regards to the type of material used to support electrical apparatuses.
    A customer is moving into a premises which has recently been tested and passed as requested.
    I noticed all the gland holes, DB partitions and missing panels are covered using 12 mm plywood.
    Rules regarding the type of material used to blank off or mount electrical equipment ?
    In some countries you are not allowed to install a plastic DB it must be a non flammable material.
    I was watching a video of a solar installation and the lad even goes as far as mounting the inverter and components to a board which is non flammable.
    I like the way they fit a document holder below the inverter.
    • 1763
    As far as I know, there is no regulation that prevents the use of wood.
    I still pass installations with old wooden db's as long as there are no fuses and all the breakers have shrouds.
      • 1763
      @ Isetech. Checked out that video you pasted. Consumer unit or DB seems to be on the low side. Don't know UK regs but here it would have to be in a lockable cupboard, being less than 1,2 meters from the floor.
      Very neat inverter installation.
