Installing a Sunsynk inverter
    The unit has arrived. Now we start the process of setting up the unit ready for installation.
    First thing I removed the mounting bracket ready to get templates made, one for my workshop wall and the modified version.
    Why a modified version, cooling, everyone talks about the importance of cooling, then you receive an inverter with a heat sink on the back of the unit which is 3 mm off the wall, really, I would have thought a little more consideration would have been taken in account for the cooling. The first modified bracket will be longer (top to bottom) and have a space of at least 50 mm away from the wall to allow for cooling.
    I a have also considered making along bracket which will support the inverter and battery with a 100 mm gap at the back, this will also allow me to fit small fans with temp control and hide the trunking or any wires I need to go up the back, that way there is no crossing of wires in the trunking.
    We all talk about AC and DC separation, as I remove the cover, the DC isolator for the PV and the AC main switch are mounted right next to each other. Come on Keith, I thought you guys would have read the some of the regs and paid attention to little details like this.
    I would have moved the first entry gland on the right hand side over to the left and fitted the AC on/off switch away from the DC. Maybe the little wires to and from the the AC switch are DC or low voltage, but we will only know as we dig deeper and learn about the unit.
    • Dylboy
      • Jun 2020
      • 777
      Another thing with DC and AC seperation is that I see you have these AC and DC combined protection boxes. Now I am not sure if there is a plastic sheet between the two compartments and then what is the description of SEPERATION ? What makes something separate...? Pvc insulation in my view electrically seperates...?
        • 3517
        Cooling in the terms referenced to a heatsink is about the movement of air to remove the heat from the heatsink. The smaller the gap between the heatsink and the wall, the better the effect, as it then acts as a chimney causing a small wind to occur. Moving the heatsink far away from the wall changes the way the air flows over the heatsink, and you lose the chimney effect, and the faster moving air over the heatsink. There was thought put into the design of the Sunsync inverter.
        A similar question would be, does a black anodised heatsink work better than a natural colour anodised heatsink?
        Actually there is no difference because it is about surface area exposed to the environment, and black costs more but does look nicer.
          • 3517
          The seperation of the AC and DC once in the equipment has no safety value, ultimately the DC negative, and the Mains Neutral are seperated by the volt drop across a diode, or 0.7V, so seperating the incoming AC/DC has no benefit other than a higher cost.
          Generally any DC switching done in the inverters are control signals, the actual heavy work is done by the power devices, such as IGBTs and FETs.
            • 1765
            When justloaded speaks things electronic, I listen and take note.
            The chimney thing does make sense.
            My braai always smoked us out until I reduced the size of the chimney and lengthened it .. got faster air flow and problem solved. Much the same as a jet stove. I think they refer to it as the venturi effect. The smaller the gap, the faster the air/liquid flow.
              Interesting, This is what I love about this forum.
              If I understand this correctly, even if I build a cabninet, I must make sure I have a solid panel at the back of the inverter covering the heat sink to ensure air movement between the fins. One of the new plates I laser cut today, must go from the bottom of the heat sink to the top of the heat sink.
              The plan was to put the inverter at the top a DB with all the differnet electrical components, fuses, isolators etc in the middle and the battery below. I am going to can that idea until I get a battery. The battery will also require cooling, it wont help if the battery is installed below the inverter and all the heat then go up. Maybe look at mounting ot the side.
              If you install a 5 kva Sunsynk inverter with a heat sink it could void the warranty if you mount trunking directly below or anything above the heat sink. I see there is a temp probe in one of the packets, I think it is for the battery.
              Apparently the 8.8 kva doesnt have a heat sink, but rather fans on the side, we will look into that, one day when I get one to tinker with.
                Now you got me thinking, that would look so cool with a black heat sink, when I install my own personal unit, I think I am going to get anodised black, the same colourt as the cabinet frame.
                  I am learning as I go, so feel free to set the record straight.
                    Taking the cooling into consideration, today I start looking at how I plan to move the DC isolator and on/off switch out from under the unit, without making any structual modification to keep the warranty. I want the new elctrical cabinet designed specifically for the this inverter to bolt directly to the bottom. I will get it built at a local panel builder who is certified to build electrical panels.
                    If I fit a DC isolator into the elctrical cabinet mounted below the inverter, there will be no need to have one under the unit.
                    Someone said to me that customer dont want to spend money on the electrical par tof the install, the way I see it, if you have have taken the step to piss R 150 k against the wall what another R20k to make it look good and be functional., with emnough space to add more circuits and even the equipment for the EV charger, smart devices and all the otehr stuff people are adding to their properties. The old days of those silly 1 tier DB are like fax machines.
                      I have installed many inverters and old type batteries (FLA/gel and AGM) and genrators, but yet to install a lithium battery and solar panels, so this will be the part I will need to pay attention.
                      The next step will be the panel requirements-
                      1/ The roof tiles, type of brackets and rails to secure the panels.
                      2/ Make and type of panels.
                      3/ The angle of the roof.
                      4/ Which way the roof is facing and how many panels can fit on which section of the roof.
                      5/ Which panels which make up each string.
                      6/ The max VOC and current capacity for the MPPT's.
                      7/ Satelite images of the roof to verify the location and space on the roof, and the location of large trees, power lines, etc, which could create shading.
                      8/ The size and type of cabling rqeuired from the panels to the combiner box.
                      9/ The route and wireways, trunking or conduit, plastic or metal.
                      10/ A very important step, isolation, where and what type of isolation will be used to "switch off in case of emergency".
                        • 1765
                        Just a question .. don't shoot me.
                        Is it a good idea to put the inverter inside a cabinet ? As far as cooling is concerned, would it not be better for it to be out in the open ?
                        All the installs that I have seen so far are in the open
                          Cooling is a priority, I have learnt that when it comes to inverters and batteries, best you fit the temp probe and make sure their adequate cooling.
                          The plan is not to fit the inverter inside a cabinet(not initially) but build a cabinet behind the inverter and the battery to hide all the wiring. I built a CCTV cabinet like this were the equipment is surface mounted but all the plugs and cabling is hidden behind it, its not as deep as a those big network cabinets but deep enough to hide everything.
                            To add to the panel requirements -
                            11/ Earthing for the panels, I see some people feel the rails can be used and you only need to fit 1 earth lug.
                            12/ Earthing back to the inverter.
                            13/ Earth spikes.
                            14/ Bonding it all together.
                            15/ All the accessories for the earthing and bonding.
                              Then we need a solar calculator. I see there calculators, if we get more than 10 installs (6 so far, 4 to go) , then I will get a paid version.
                              If you know of any good free calculators, let us know.
