I feel such gratitude for your feedback.
I came here to mention the idea that I had, of riveting a 1mm thick sheet of aluminum to enclose the bottom right corner of DB1, such that the geyser and lights wires would be totally inaccessible and invisible in DB1, and would exit the right side of DB1, going into adjacent DB3.
But the multi-tier surface mount DB idea is just so clean and will be easy, straight-forward to CoC without complications and issues.
There is also value in replacing the complicated mess with a single DB.
So I think it's a winner.
At this point I'm thinking to replace DB1 and DB3 with a single 2 tier surface mount DB.
It would be the cleanest to have a 3 tier, and relocate the batteries and inverter close to the DB, so that all alternative supply stuff can flow out of a single DB.
Because currently the batteries and inverter are far away, so the current tentative plan is to have a DB2 at the inverter that does EL, and that has a cable run that feeds the main DB and some plugs along the way.
I'm reluctant to move the batteries and inverter to near the main DB because then they'd be far away from possible PV panels which may be added in future. Long PV wire runs are inefficient. It's only a 12v system.
If you have any further thoughts I'd be very interested.
I will discuss the main DB replacement with my contractor.
