This is the best news this week. We use these magneto literally every single day on site, the old lead acid version lasts the entire day and some.
I cant wait to get my hands on the new lithium version, I just hope they are as good as the lead acid version, and we get more than a year out of the batteires.
If you look at the comment section, you will notice a comment about the USB cable, you must use the one supplied with the light for it to functuion correctly.
And even more good news, sherlo have released their lithium 3 amp power supply. I have just been using the drop in lithium 7 amp with the older version, which has worked for me.
3 AMP Power-Supply Battery charger with Low Battery Cut Out: 3A_Lithium Charging of 7AMP Lithium batteries Alarm panel Battery backup CCTV Battery backup Backup power supply for door controller. Magnetic lock for an Access Control solution Microprocessor Controlled charging output. Current limited 2AMP Low battery switch off at 10V DC. Over voltage protection >15V Resettable […]
