Now I remember why I dont buy Major tech testers.
that saying if you want something done right, do it yourself.
IF you have an MT 250 and cannot get the unit to connect to your computer.
You need to get hold of the USB stick that comes with the new units which has the correct software.
IF you are using windows 10:
The software and drivers that Major tech send you will NOT work, they are missing setup files.
You must remove the software from your computer and restart the computer.
Once it has restarted, plug in the USB and click on setup, let it load and once the software is loaded, then go back and click on the drivers and run it.
Connect the MT 250 and click on date and time, then ok, after 3-5 seconds it is not "connected" the software and drivers are the problem.
If you are using windows XP
You just run the setup file and you dont need to install the drivers, it will automatically link to the device.
Would I spend R6000 plus on a MT 250, definitely not, it is only single phase, no wifi, no app to control the device, it still uses dos base software. and dots for the recording.
