edit
Built-in intelligent battery charger prolongs battery life
Battery saving function prevents the batteries from going flat when not in use
Low battery disconnect function automatically disables inverter when batteries reach minimum charge
Fossil fuel and pollution free
Input power : 24 Volt DC
FBIT2000.pdf
FBI2000W.pdf
pricecheck
This is the FBI2000W inverter/uninterruptible Power Supply AKA UPS unit build by ELLIES and available at a cost of about R8550 (give or take) for the unit. You get two 12 Volt 100 Amp batteries "depending on model and distributor and specifications. It is cool looking system and is like a normal UPS we all love and know form the PC world.
This unit is able to handle a second set of batteries or so i am told. So it works just fine BUT there are a few things you need to know about this system.
First and foremost is the running cost. It will consume about 129 Watts of power while charging (again based on this model others may be more or even less) Batteries will set you back about R1600 to about R2500+ depending on make or model.
Secondly it has two settings. The one is called "Narrow" and the other is called "Wide" Now the trick here is you need to identify what you want it to do. If you want to run. The "Narrow" setting is used for "tube lights, energy saving lamps Television set" NOTE NOT SUITABLE TO MEET HIGH POWER MOTORS and they even warn you about a PC... The mode runs within 170-280Vac
Now the second setting "Wide" is recommended for things like "lamps and or a fan" The mode runs within 90-280Vac and is not as sensitive or so the manual claims.
Now on a high load you will get a couple of hours but according to the box and manual on lower loads it will last longer. Now my power load will be in the 240 watt range so i am not to worried.
But base on the info i got i will be installing a second system just for my Freezer and refrigerator and this one will be used for my basics.
Last thing when you turn it on it will make a fizzing noise and if it switches to the inverter the fans kicks in and does make a noise.
Cool thing is the power consumption my generator can charge this system with ease and that to me is a big plus.
hope this helps
